Windscreen Washer Motor
Has thanked: 505 times
Been thanked: 451 times
My washer failed to work last week and I've just discovered why:
The motor is rusted solid, no movement at all between the rotor and stator parts. The drain hole for the motor had become blocked and water has clearly found it's way past the seals.
Does anyone have a working one I can purchase?
Porters2
Has thanked: 112 times
Been thanked: 133 times
Re: Windscreen Washer Motor
Post by Porters2 »
I have a spare bottle that is split, I am positive that the motor works fine, yours if you want it mate.
Steve.
Has thanked: 628 times
Been thanked: 218 times
That is pretty tasty there aye. I sometimes think about swapping the bottle, motor, and/or nozzles over to something a bit more modern that has more power or the fan sort of spray pattern. Something along those lines :lol:
Porters2 wrote: Tue Oct 24, 2023 5:45 pm I have a spare bottle that is split, I am positive that the motor works fine, yours if you want it mate.
Steve.
:thumbup: you have a PM Steve!
Hobbawobba wrote: Tue Oct 24, 2023 7:09 pm That is pretty tasty there aye. I sometimes think about swapping the bottle, motor, and/or nozzles over to something a bit more modern that has more power or the fan sort of spray pattern. Something along those lines :lol:
I thought about that, but want to try and keep this car as original as possible :)
Casey wrote: Wed Oct 25, 2023 3:32 pm
I don't blame you there aye bro :lol:
You can take the washer motor out of the bag that’s the rear washer reservoir, they are the same motor
Return to “Wanted”
