My washer failed to work last week and I've just discovered why:
The motor is rusted solid, no movement at all between the rotor and stator parts. The drain hole for the motor had become blocked and water has clearly found it's way past the seals.
Does anyone have a working one I can purchase?
Windscreen Washer Motor
- Casey
- Has thanked: 505 times
- Been thanked: 451 times
- Has thanked: 112 times
- Been thanked: 133 times
Re: Windscreen Washer Motor
I have a spare bottle that is split, I am positive that the motor works fine, yours if you want it mate.
Steve.
Steve.
- Has thanked: 628 times
- Been thanked: 218 times
That is pretty tasty there aye. I sometimes think about swapping the bottle, motor, and/or nozzles over to something a bit more modern that has more power or the fan sort of spray pattern. Something along those lines
- Casey
- Casey
I thought about that, but want to try and keep this car as original as possibleHobbawobba wrote: ↑Tue Oct 24, 2023 7:09 pm That is pretty tasty there aye. I sometimes think about swapping the bottle, motor, and/or nozzles over to something a bit more modern that has more power or the fan sort of spray pattern. Something along those lines![]()
I don't blame you there aye broCasey wrote: ↑Wed Oct 25, 2023 3:32 pmI thought about that, but want to try and keep this car as original as possibleHobbawobba wrote: ↑Tue Oct 24, 2023 7:09 pm That is pretty tasty there aye. I sometimes think about swapping the bottle, motor, and/or nozzles over to something a bit more modern that has more power or the fan sort of spray pattern. Something along those lines![]()
You can take the washer motor out of the bag that’s the rear washer reservoir, they are the same motor
