Relay Check Lamp (8598)
Has thanked: 505 times
Been thanked: 451 times
Re: Relay Check Lamp (8598)
I'm not 100% sure, but I don't think that will work. If you were correct, there would be no reason for the circuit to have that reed relay at all in the original design.
The current flowing through the reed relay and the timer operating the conventional relay have to work together. If you bridge the reed, the sequence will be interupted and the indicators will stick on I suspect.
I don't know why a modern LED flasher module shouldn't work, as long as you completely by-pass all the existing circuitry. Leaving any of the OEM circuit in play will lead to some weird effects.
84_12a_brap
Post by 84_12a_brap »
Oh ok, I see. So I don't need to replace the current flasher relay with an LED one I need to replace the whole circuit with an LED flasher relay. Sorry don't know that much about electronics so learning as I go along!
Now just to confirm so I don't break anything beyond repair. I'll need to cut the R & Q wires on the harness that goes into the CPU, route these through a three pin flasher relay and then run the third pin on the relay to ground, is that correct?
I can't be 100% certain, but yes, that should work.
If you cut the wires carefully, with enough of a wire tail on the connector end, you can always reconnect the two wires later, to return to stock, or in case there is an unforeseen issue.
Return to “Electrics”
