We have to viscous coupling...was seized totally, but have a fan and shroud on the suck side set at about 85 degrees currently which may be a little cool/early. The gauge in the cur runs about 1/3 up I guess...into normal sector but under halfway in todays 9 degree weather.
Just a little juddering to sort at slow no throttle over run speeds...though idle has settled a bit low which may be it.....or perhaps user error not used to lack of torque from a rotary!
