Headlight motor relay
Herman
Post by Herman »
Hi All,
I'm after a headlight motor relay - Nippondenso part number 056700-5950 (which is printed on the unit).
I believe the MAzda part number is FB01-51-663.
(But I think all the FB headlight motor relays are the same anyway. )
Let me know what have you. :)
Thanks,
Pete
Re: Headlight motor relay
Hi Pete, I will check tomorrow as I think I have one,
regards Pete
Herman
Post by Herman »
Thanks. Let me know if you have a RH side headlight motor too - got a feeling a I might need one! :oops:
Herman
Post by Herman »
Believe I now have one on the way - thanks RX7FB.com !
1of1
Been thanked: 7 times
Post by 1of1 »
Hi all
Anybody have the pin layout for Denso 056700-5950 Headlight Relay ?
Thanks
Phil
1of1
Post by 1of1 »
Lights now all working.
Started off at the fusible links, all appeared ok.
Then tested feed to relay from Retractable light switch, also ok.
Tested RHS relay, all working.
Then found missing + feed on r/w cable.
After several linking out procedures to check light operation
traced back to where I started faulty connection in top fusible link spade connection.
Attached relay information for future reference.
Return to “Wanted”
