84GSLSE 13BREW Swap build
Re: 84GSLSE 13BREW Swap build
Pic Heaven.
Very clean work, looks lovely
Good to see two new young Rx 7 enthusiats have a lot of fun with the car. BTW my full respect your brake and suspension upgrade looks fantastic. th: s(c)
DWNUNDR
Has thanked: 39 times
Been thanked: 49 times
Post by DWNUNDR »
spirit r wrote: Mon Jan 22, 2018 4:21 pm Good to see two new young Rx 7 enthusiats have a lot of fun with the car. BTW my full respect your brake and suspension upgrade looks fantastic. th: s(c)
thanks..
yeah all 4 of my kids follow whatever Dad thinks is cool... to a point.. guns, dirtbikes and cars.. hahaha
gets expensive
DWNUNDR
Post by DWNUNDR »
few more pics from the BBK build...
Image Image
Image Image
Image Image
when you cant find shims online then you make your own
Image Image
DWNUNDR
Post by DWNUNDR »
Attempted my first ever AN braided lines tonight.. think Innailed it.. what a bitch to work with haha
Oil cooler lines..
1 down.. the other tomorrow...
good stuff, that looks great.............and yeah, they are a bitch to work with :)
Does you have to change your wheel offset cause the BBK reconstruction giving your wheel another position.
DWNUNDR
Post by DWNUNDR »
spirit r wrote: Sat Jan 27, 2018 9:01 am Does you have to change your wheel offset cause the BBK reconstruction giving your wheel another position.
nope.. the weel offset changed due to going 17s and wider.... the BBK I made uses my factory hub... I turned the disc part off of it allowing my to use a slip on rotor for from a 2nd gen... TBH I misread a post online that was meant for making the kit for a 2nd gen series 4 to a series 5 4pot setup... http://www.aaroncake.net/rx-7/4lug4potbrakes.htm.. actually I guess maybe a little bit as you have the added thickness of a rotor on the hub face.. so.. .200" outwards maybe less
I had been searching for BBK kits for a 1st gen and came across this site... in my excitement I totally missed the finer details.. hahah
There is a guy who has remade a BBK kit that went around a few years back and is now selling them.. but the kit (not including calipers and discs and pads) is around $400... he does sell them for small spindle setups too...
My whole kit cost me around $250 and thats because I had a major brain fart and milled the tabs on teh first set trying to figure out offset, only to have it occur to me if I had to replace a caliper Id be screwed... so I bought a 2nd set... first set cost me $80 and 2nd set about $100...
now of course once I figure out if it all works correctly once it is on the road I may tweak it some and produce the setup.... maybe.. probably not as I am not sure I want the liabilty...
DWNUNDR
Post by DWNUNDR »
Couple more little treats...
