Running 12a / 13b six port
Useable 12a housing / S3 front rotor
13b housings for machining (is machining uber expensive)??
S4 gearbox (if the motor is out then why not)?
S3 is different to S1/2 so needs to be the same or swap rotating assembly.Marc S wrote:Probably not much help to you, as I won't know until the winter, but I might have a spare rotor and housing going - does it have to be S3?
I'm learning stuff too mate .. ask all the questions you likeMarc S wrote:Dave, I'm really sorry to hijack your thread a bit here...but I'm learning stuff!
