85 fb elford turbo
ruby
85 fb elford turbo
Post by ruby »
hi all
i just bought my first rx-7 a year ago and what started out as a litlle fix up ended up in a total restoration :D
A lot has changed since i bought it a year ago but i´ll start with the beginning.
When i bought the car it was in terrible shape the paint was all messed up since it had been stored in a room where the previous owner spraypainted his cars :shock: , so on the paint where all sorts of colours and mostly thick primer. The car was also heavily rusted at the rear jacking points and in the rear wheel arches where the suspension arm is mounted to the body. the engine fired up pretty much from the first try so that´s good, but i am thinking of buying a second one and take it apart so i can try to do some porting on it an see how that would react with the turbo set up :d.
I have to mention that it isn´t an original elford turbo but i bought the kit after i bought the car. Any way when i got it home i started to take the car apart altought this wasn´t the original plan. But i figured i might as well do the entire thing when i´m at it :roll: . i also cut out the rust on welded in some new metal on the rusted area´s ( lot of work there ). The car also had a couple of dents so pulled them out as well as i could and filled it with bodyfiller. after that a lot of sanding :D. I also scraped the bottom of the car and put a fresh coat of bitumen on it. After getting rid of all the rust ofcourse :D. every suspension part and the entire drivetrain was brought to the sandblaster, the smaller things like bits in the engine comparment i´m gonna sandblast myself. Next i sanded the entire car to the first original primer coat and since this was still good i started from there to paint the car. original colour was black and i did painted it black again but not the original. It was the first time i painted an entire car so i was destined to run into some problems :evil: . first one was i painted in my garage so there´s a lot of dust in the clear and i have one or 2 runners in the clear. Luckily a friend of mine is a buffer at a local bodyshop and he can help me out with sanding the clear and buffing it :D . the parts that were sandblasted all got a coat of black paint on it, only some of the things are gonna be painted gold or copper. All the suspension rubbers where replaced by poly ones and the original springs are replaced by a set of new lowered ones, altought they didn´t do much lowering :p. Then the whole suspension was put back under the car. I also got the rims repaired by a friend of mine and podwercoated so there like new. It aren´t the original rims but i like em so i Think i´m gonna keep them :mrgreen: . I gave the engine a clean up and put it back in only to notice that i should have marked the pulley on the crankshaft because it fits in four differnt positions :oops: . I just started to put the elford kit on it and this fits perfectly :twisted: .
But there´s still lots to be done :D , i still have to took a look at the calipers because these where stuck. waiting on the radiator te be fixed, also need to get the seperate oil cooler and oil lines and some other stuff :D
well thats pretty much i don´t really have a lot of pictures but i´ll try to put up as much as possible :D
here´s the beginning :
rx7 rear.jpg (41.22 KiB) Viewed 5676 times
rx7 int.jpg (38.02 KiB) Viewed 5676 times
rx7 front.jpg (36.75 KiB) Viewed 5676 times
´´speed has never killed anyone, suddenly coming to a stop that´s what´s get you ´´
ruby
Re: 85 fb elford turbo
Post by ruby »
these are the only pictures i found so far :oops: A friend of mine has some of the paintwork so i´ll try to post them as well
cleaned up engine with the elford setup
painted rear axle
painted rear axle
BO0557
Post by BO0557 »
Hey there those t2 turbos are so so small for a rotary it's not funny!!
If your after some Elford side skirts and rear spats I have some I am
Not going to use..
ruby
Post by ruby »
sure i´d love to get those sideskirts and rear spats off your hands i´ll pm you my e-mail adress :mrgreen:
And why do you think those turbo´s are too small ?
ruby
Post by ruby »
does anyone know what it means if you have a tag on the glove box that says ´´black rotary nr18´´
Having asked a bunch of people i thought i´d ask here :p
thx anyway
Post by RamoNZ »
ruby wrote:sure i´d love to get those sideskirts and rear spats off your hands i´ll pm you my e-mail adress :mrgreen:
Partly because of the modern convention to fit large turbos to rotarys. The standard Elford turbo will be fine on a car with stock to +30% horsepower, but more than that and I'd look to upgrade to something more efficient, that typically means larger because of the amount of exhaust gas that the rotary engine flows and the way the hot and the cold side of many turbos are matched.
Nice car by the way, jealous that Europe got the US GSL-SE spec interior for the series 3 cars, while we got something different and more like the Series 2 whereas yours is more like series 4. The plush leather looks cool too :lol:
Rogier
Post by Rogier »
ruby wrote:does anyone know what it means if you have a tag on the glove box that says ´´black rotary nr18´´
thx anyway
I believe it was a limited edition, black exterior, lether interior and I believe special rims etc. Pretty rare I think. Take good care of your car, it's a keeper!
FB just for oldskool driving fun
FC TII vert (modified) just to annoy FD's
Are the turbos so small due to the problems of cooling the charge? Obviously you can't have a carburetted application blowing through an intercooler cos then that makes basically a bomb out of the 'cooler. Maybe the turbo is kept small to avoid shoving too much air in too hot?
Just noticed, besides the leather, the dash is not UK standard. Is is from an FC?
The european version of our Series 3 came with US spec dash.
