... Called it roxy as we looked online for the stripper name of my girlfriend and it turned out to be roxy. Here is a pic, will get some better ones one day.
So far I have replaced all the cooling system pipes, rebuilt the rear brakes and fitted new hoses and hard lines as well as rebuilt the carb and had a small amout of welding done. Do most of the work myself but some things I will send off if the cost is not too high and I am confident that a good job will be done.
As per some of the other posts, next on the list is to sort out the rusty and leaking fuel tank as well as sort out all the exhaust leaks. Here is a photo of the tank. The wet spot is the leak (obvisouly) and the closest corner is rusty and had been repaired in the past.
I also managed to aquire one of these.
http://www.somerfordmini.co.uk/eshop/in ... s_id=14882
An 83mm inlet K&N filter fits on the end nicely. Reckon its worth about 0.01hp but looks nice.
Over the winter I want to clean off the underside and replace all the bushings.
Tim
