FS: 1985 Silver FB
BO0557
FS: 1985 Silver FB
Post by BO0557 »
Hey Guys,
Im selling as a roller as i cant be bothered and want to do some more upgrades to my 1300 back home.
The car comes setup for a turbo engine. It comes with a 3" exhaust with large stainless rear box, 3 row radiator and 16" Spal thermo, battery key and battery is located in the boot, fuel tank has had a resto done on it and has no leaks.
To get it running it will need a motor, box/tailshaft , exhaust and fuel pump to get going as a NA or throw a 12a or 13bt in and wire a ecu + pumps
The car also has a brand new LSD and wheels have been referb. Car has a good grey interior with centre dash modified for 2 gauges.
Looking for £850 with LSD, radiator and exhaust or willing to negotiate less parts. Car is SORN'D and located in Bromley, Kent.
contact via pm or bo0557@gmail.com
rei99
Re: FS: 1985 Silver FB
Post by rei99 »
A little question: LSD was not only on USA cars? :?:
Not fitted on factory UK cars Davide. The seller is saying this LSD is new.
BO0557
Post by BO0557 »
That's correct I have the standard open centre and I have installed a lsd which I rebuilt and put in..
rei99
Post by rei99 »
W(p
Do you want to sell it with the propeller shaft and other parts to put on Mk.I/II? Thanks! 0-0
BO0557
Post by BO0557 »
i dont have any FC parts
Post by RamoNZ »
BO0557 wrote:i dont have any FC parts
I think he means S1/S2 as in parts to make his 24 spline and small axle back end into S3.
And prop shaft as its got the larger flange - but yours has the S5 turbo yoke which won't fit an NA box.
rei99
Post by rei99 »
0-0
Has thanked: 5 times
Been thanked: 23 times
Post by DB RX63 »
What happened to the front bumper, looks a little bent ?
Is the front panel damaged as well ?
BO0557
Post by BO0557 »
the front panel seems ok - just needs to alignment work on the bumper rio which i have a replacment bumper which comes with it..
