cooling
rustyrescue
Has thanked: 1 time
Been thanked: 38 times
cooling
Post by rustyrescue »
After taking out RX to Beaulieu it ran well but under load/traffic crept up too warm still. I have a radiator coming as ours has a leak...small.
I thought a check of the new thermostat against an original in a box of bits would be good and the hole in the pattern new one I got is tiny!! so ran with no stat as a test and its even warmer!
Can anyone explain that.....no airlocks it seems, heater works in car.
Porters2
Has thanked: 112 times
Been thanked: 133 times
Re: cooling
Post by Porters2 »
[/quote]
Hi Russ,
On some vehicles removing the stat creates a short circuit, this causes the car to overheat as it bypasses the radiator.
( something I learned the hard way as an AA patrol years ago)
rustyrescue
Has thanked: 1 time
Re: cooling
thank you.....that is interesting, the rad gets warm and top and bottom hoses warm so it does get flow BUT perhaps along your line it could partially bypass it/reduce rad flow? though really not sure how!
I will fit the new Rad we await, the original now tested stat and prior to that give it another flush out warm and back flowed with a hose in case a little use has stirred up sludge.
Fingers crossed g-l
Return to “Cooling”
