Anyone have a good usable 12a centre plate for sale?
Mine has tiny ports with NO cast into it. would like the small port variant if anyone has one.
Im thinking of 3 rotor short engine with PP housings so small ports means less to fill with devcon etc.
Let me know.
Regards
Jamie
12a centre plate
- gt_james
- Has thanked: 114 times
- Been thanked: 211 times
Re: 12a centre plate
Might want to look at buying from overseas if you want to exactly match that centre iron you had off me, that ones not a UK market part, I think "NO" irons are Jap market.
There were other irons with the small port, but I don't know all the casting codes. Generally they're not that desirable due to the small port, but like you say ideal for a PP build.
I don't know how much of a rush you're in for it, but I have a JDM 12A 6port, which I haven't decided what to do with yet, It might find it's way into my yellow car as it's a running engine, or I might pull it apart and use the rotating assy and I'd be interested in swapping the irons for tall port irons to build it as a 4 port 12A. The centre iron is a small port, like a "NO", It will be a later 83 onwards iron so would be nitrided and I think it has the overhead ACV port and doesn't have injector holes either, like your "NO" iron. There is a small difference though, the iron has a boss and studs on for mounting the engine off the centre iron in the HB cosmo, that may or may not be useful to you in mounting a 3 rotor in whatever you're putting it in, but won't do any harm if you weren't to use it.
- JamieR
- Has thanked: 10 times
Thanks James
No immediate rush but definitely interested in that if you pull it apart. Im just getting various prices for E shafts at mo. I may stick with 13b if prices get stupid but lets see
J
J
It's just rotors and GRP
