gearbox and axle oil?
rustyrescue
- Has thanked: 1 time
- Been thanked: 38 times
do In I need to stay off GL5 spec oil and use GL4 as with other old cars I have (older!) due to the issues with bearings/bushes??
- gt_james
- Has thanked: 114 times
- Been thanked: 211 times
Re: gearbox and axle oil?
Gearbox GL4 or GL5 SAE 90w or 80w90
Axle GL5 above 18C SAE 90w or below 18C 80w
I use redline 75w90 GL5 in the axle and redline MT90 75w90 GL4 in the box.
If you have a stock clutch type LSD you need LSD gear oil, or use an additive for LSDs.
