water pump housing
water pump housing
Does anyone know where I can source the little shims that fit on the studs? I can only seem to find them at Mazdatrix and they would like to charge £22 to ship 2 tiny shims and a gasket. :o
Part number 1757 15 106
The missing shims are the cause of a very small coolant leak.
marksport
Has thanked: 13 times
Been thanked: 97 times
Re: water pump housing
Post by marksport »
Will see if I have any in my spare engine bits pile..
Apparently, they should be fitted on the two studs that don't have a gasket. They are meant to compensate for the gasket thickness and keep the housing on a level plane. Thanks in advance for looking. :thumbup:
Ebay should be cheap and easy enough to get some from bro
I’ll have some here mate
marksport
Post by marksport »
Found some if you still need then...
Thanks for looking guys. I have some now. Rather innocent looking things but so important and easy to miss. rdg
Return to “Cooling”
