light horn
light horn
Trying to sort out some electrical gremlins. When i pull the switch, the lights go on, but they don't pop up. Other strange issue: When i put on the driving lights, all seems normal. Switching to high beam, lights go out but stay up.Light horn does work.
Re: light horn
Check your fusible links on the n/s front strut tower, headlight motors and main beam goes through them
Re: light horn
It must be that the combination switch is faulty. Looking at the wiring diagram, on the switch there is a section mentioned,dimmer or passing. "Dimmer" does'nt work for high beam. i will test it tomorrow. A nice tour planned for today with the 929 hardtop.
