I'm finally getting Rexanne back up and on the road. Preparing for the MoT today though, I think I made a boo-boo...
One of the headlights was 'winking' every time I turned the lights on or off - raising and lowering repeatedly before finally settlin' in the desired position. Easy, I thought; I swapped the relays over and the problem occurred on the opposite side. So I figured a replacement relay was needed.
Here's where it turns South though...
I found a 5-pin Nippondenso relay in the garage that looked similar to the old one. It had a different part number (056700-8830 versus the 056700-5950 stocker), but what's the WORST that could happen right??!
Well, the answer is that I now have a headlight motor that won't go up OR down, even with the "good" relay in it. What have I fried? I tested the motor itself works by jumping across from the Red/White wire on the motor (12v perm) to the White wire, so I'm guessing it must be some wiring or something? The other headlight goes up and down perfectly, as designed. (The headlight itself also switches on and off, it just doesn't 'pop up'.)
Separately, does anyone have a cheaper source of the headlight motor relays (part #056700-8950 / FB01-51-663)? I found a seller on eBay but he's after £30 for a second hand unit.
