I can't take the measurement off mine as my springs are lowered aftermarket items. Thanking you in advance
Coil springs fitted length
Does anyone know offhand (probably not) or could you measure the length of a front and rear OEM spring while the car is on the ground. This is commonly referred to as 'fitted length).This is easier done on a lift if you are lucky enough to have one of those. This is the final measurement I need for getting a set of springs made.
