Interchangeable parts FB & FC
anyone know if a FB clutch master cylinder will fit on a FC?
Been thanked: 187 times
Re: Interchangeable parts FB & FC
ian65 wrote: Thu Feb 15, 2018 8:45 pm anyone know if a FB clutch master cylinder will fit on a FC?
I just had a quick look on Rock Auto & compared the FC CENTRIC Part Nos & the BECK & ARNLEY Part Nos..............for the same FB Items & they are not the same.
Not all FB MCs are the same either
Not sure if turbos are different but the S4 NA one was interchangeable on my s3
gt_james wrote: Mon Feb 19, 2018 2:10 pm Not sure if turbos are different but the S4 NA one was interchangeable on my s3
sadly the turbo one mounts differently.... pity.... I've got a new S3 slave on the shelf
Victorsanders
Has thanked: 59 times
Been thanked: 97 times
Post by Victorsanders »
“Apparently” the S4 NA Manual starter motor is a straight swap and significant upgrade to the S3 Manual Starter motor. Anyone have any experience with this ?
Has thanked: 627 times
Been thanked: 218 times
Victorsanders wrote: Fri May 31, 2024 3:40 pm “Apparently” the S4 NA Manual starter motor is a straight swap and significant upgrade to the S3 Manual Starter motor. Anyone have any experience with this ?
That wouldn't surprise me aye bro. I don't know about the power difference. But I think a far more beneficial thing would be to get all new 70mm2 battery cables and clean up all the connections on the body/starter aye :thumbup:
I'll have to go through my parts, but I think the S4 UK spec is the same starter as s3. The US spec S4 starter is a gear reduction starter, and can be upgraded to a more powerful motor.
Return to “2nd Gen RX7 Technical”
