Identify these connectors - 12A engine
Kirkosaki
Post by Kirkosaki »
Hey. My car is an 84 GS model with the 12A engine. It is left hand drive.
Can anyone identify these connectors. They are located right next to the firewall and are coming off the main wiring harness. One has has three wires going to it. One wire I removed and it was a black GND where the jumper wire loops back.
The other connector has three wires as well. I think it may be a main relay?
Note* The car runs great with right now without the jumper wire going anywhere. Just curious what it is for.
Thanks!!
84 GS-S
Re: Identify these connectors - 12A engine
Hi Kirkosaki,
I think the connectors is for some optional accessories like power steering, Automatik Transmission. Cause OPTIONS like Cruise control, sub zero you find on the otherside of the engine room.
You can also check the colour Code of the wiring here:
https://drive.google.com/file/d/0B4M7Pr ... qPQP&hl=en#
not sure seems to be connectors for the kick down relay so you drive AT
Kirkosaki
Post by Kirkosaki »
I just ended up removing the jumper wire and just cutting the other end, tucking it away. haha.
The other black connector I just left alone. I have a manual and found a good one online, but couldn't seem to trace it out. Ah well! no worries.
84 GS-S
Return to “Electrics”
