Exhaust Mounting Points
Could one of you please supply some photos of the exhaust mount points, or a photo of the underside of an fb ( my google skills are lacking today )
In particular i am wanting to look at the mid mounting point for the hanger by the gearbox rear mount. I am guessing there is supposed to be some kind of bracket there, and mine is long gone.
Thanks in advance.
James
Re: Exhaust Mounting Points
I should be under my car in the next day or two. I'll grab some pics if noone has posted by then
Yes, there should be a bracket hanging from the side of the rear of the gearbox. It's 2 tapped holes for the bolts.
It's a triangle shape on the early cars. It mounts to a clamp around the pipe(s).
Clamp (top left):
This is what my red one had when I bought it:
It's pretty much solid mounted to the box and then goes flexy afterwards.
Thanks Tool
Does any one have some photos of an original mount set up?
