Headlight Issue
DeanRX7
Has thanked: 39 times
Been thanked: 63 times
Headlight Issue
Post by DeanRX7 »
Hello all,
Any advice on headlights issue welcomed.
A few months back the drivers side headlight motor seemed to die but other popped up and turned on no problem. The left went up with the switch as well. Now both have died and wont pop up or even turn on. Fuse seems OK and I have seen many other issues with these but not this any suggestions?
Thanks.
DeanRX7
Re: Headlight Issue
Post by DeanRX7 »
Also, while I have the headlights out, I thought, if its easy enough, does anyone know of a direct hella replacement for the light inserts. I see them on ebay and alike, but the screw connections dont look like they will fit.
Any suggestions, or links on here that I have not been able to find?
Re: Headlight Issue
DeanRX7 wrote:Also, while I have the headlights out, I thought, if its easy enough, does anyone know of a direct hella replacement for the light inserts. I see them on ebay and alike, but the screw connections dont look like they will fit.
If you absolutely must have hella, it's this one here. 'left hand traffic' is the important bit so that it's the proper RHD beam pattern. Search Hella, 7 inch, H4
http://www.ebay.co.uk/itm/H4-7-Inch-Hea ... SwBahVgC9j
or did you want the sealed beam version?
DeanRX7
Re: Headlight Issue
Post by DeanRX7 »
OK...this is where I sound like an idiot. I dont need Hella by an means, but its just what I have found on my searches. Have you got these and are they easy to put in? Whats the difference between the sealed beam version and left vs right hooker drive version?
Re: Headlight Issue
Cut and Paste Post I made a year or two back on here.......
"I had an MOT advisory a few years back due to reflector tarnishing / blackening.
I found the exact replacement 7" headlights from a small guy on the net (Cibie = Valeo nowadays).
Then I put in same wattage bulbs (no wiring issues), Osram I think, but 20% or maybe even 40% brighter (New technologies in lamp making).
Result and dead easy. Except I kept the old light units.....taking up space in my loft. Why for God's sake? .....That's just me...... "
So if you search for 'Cibie' or 'Valeo' you should find them.....they are called 'semi sealed' because the reflector and glass are sealed together but the lamp can be changed from the back. A sealed unit has the filaments integral......common fitments in 1970's......disgusting idea!
Hope that helps.
Marc S
Re: Headlight Issue
Post by Marc S »
MX5 Mk1 lights are the same fitment :)
Re: Headlight Issue
Return to “Electrics”
