Just found these so bought 2 seem very cheap.
http://www.eurocarparts.com/ecp/c/Mazda ... f4d&000325
Cheap Thermostats
- Has thanked: 473 times
- Been thanked: 253 times
Re: Cheap Thermostats
Good find, also the sealant is on the thermostat mounted too, as i can see.
- Been thanked: 187 times
Don't forget to dip the bolts in some grease before put them back in housing, just in case you have to take it off again.
Remember KIWI Dave!DKWW2000 wrote:Don't forget to dip the bolts in some grease before put them back in housing, just in case you have to take it off again.
I for myself changed the bolts into stainless steel bolts and always take some graphite grease Pete!
Thomas I have also changed to stainless & use ZX1 grease
I will change the bolts when I replace the coolant this week I was in a hurry to change the water pump housing for the weekend so only refilled with softened water. I might buy a couple of those stats for spares too. Looks like there is a range of opening temps too.spirit r wrote:Remember KIWI Dave!DKWW2000 wrote:Don't forget to dip the bolts in some grease before put them back in housing, just in case you have to take it off again.
That is FC thermostat in the picture. They have rubber ring and location to fit it in the housing.spirit r wrote:Good find, also the sealant is on the thermostat mounted too, as i can see.
Not at this point. Depends if it's a stock photo or not.
You can always rip the rubber piece off anyway. You shouldn't use that on an FB.
