SA to FB fitting
m swann
SA to FB fitting
Post by m swann »
Currently working on an SA. I keep forgetting that FB brake and clutch pipe fittings are not interchangeable.
So two questions
1. If I swap in a FB clutch master, slave and tubing will it work ? I know if I put a FB Brake master in I need to redrill and make "other" adjustments.
2. Is there a conversion fitting available rather than re -do all the brake line end fittings. ??
When in doubt....hit the gas.
