Testing OMP on 12A
Trailblaser
Testing OMP on 12A
Post by Trailblaser »
Hi all, I am planning to fire up my S2 with stock 12A in the not too distant future, and was wondering if anyone knows how to check if the OMP is working, before I start the engine for the first time in about 8 years, and hopefully without dismantling it ??
Trailblaser
Re: Testing OMP on 12A
You have to test it with the engine running.
Add some 2 stroke to the fuel tank and poor a little down the carb while cranking before you do start it up properly.
Once running, disconnect the OMP pipes to the carb and let them drain into a measuring cup. See how much you get over a fixed period of time. I can't remember what it should be but I think it's in the Haynes manual.
