So, on my Series 3 there's a plastic expansion bottle mounted to the side of the radiator shroud. It has a single hose going to/from it that is sourced from the filler neck for the radiator. The hose leads into a kind of big straw integral to the cap, that then sits in the coolant in the expansion bottle and goes down to nearly the bottom of it. There is a "high" and a "low" level marked on the tank.
Now, by my understanding the coolant is fed into the bottle from the radiator when it expands so much from heat it pressurises into the filler neck, forcing the cap mechanism to allow it past. But then how does it return to the radiator from the bottle, given there's only the one hose connecting them? Is it simply sucked back by the change in pressure as the coolant...well, cools down? The expansion tank doesn't appear to hold pressure, or be designed to. The reason I ask is I'd quite like to replace the ugly plastic bottle with an alloy one, but I don't want to screw anything up. Would it be OK to install one where the inlet/outlet union is on the bottom, because the sort of straw thing attached to the original cap setup seems a bit of a stumbling block? How crucial are the level markings on the tank? I always just kinda check the rad is full by looking in the filler cap. I know it seems a bit pointless just for aesthetic reasons, but as an FD owner I have a morbid dread of cooked plastic bottles splitting and costing you your cooling system. If, as it seems, the tank is just a little overflow reservoir that does next to nothing then happy days! If I'm going to cause endless coolant level problems then maybe I'd better leave it...
Cheers, thanks for being gentle with me, lol
