These were stripped, painted and had the seals replaced with new about 3 years ago..... they've been in the loft ever since.... could now do with a strip and repaint before use just to make sure they are still ok but the seals should still all be good to re-use.... they were new 3 years ago.
Because of this, I am selling this pair of rear calipers as core items for rebuild only..... you might be able to put them straight onto your car and they may be fine.... there again, they may stick.... your choice....., personally, I'd pop the pistons back out and check them over again.
£30 plus £15 p+p .... or you can collect them yourself and save on the postage.
Series 3 Rear Brake calipers
mc turbo
Re: Series 3 Rear Brake calipers
ahh man just my luck an hour too late! been after a set in the wanted section for a while, if this falls through I`ll take them cheers mick
Thanks MarcMarc S wrote:Yes please
That reminds me...I'd better pay you for the fronts too
