Wanted - rear suspension bits
Has thanked: 512 times
Been thanked: 455 times
I'm in the process of refurbing the entire rear underside of my car and need to replace some damaged bits. Anyone got a rear lower suspension arm (without the kink, see pic :D ) or a Watt's link with two intact fixing studs - not one with thread sheared :oops: and the other with a seized metal bush :D
Or best place to source (Tim at RX- Motors? Someone closer to Colchester?).
Return to “Wanted”
