I'm chasing my electrical gremlins and would like to find the following little items
Check relay  (located behind the left front strut tower in engine bay)
Hazard lamp switch
Hazard lamp relay
Oscillator  (located behind the left headlamp in engine bay)   Got one off JImmys but had pins missing   grrrrrrr
						S3 electrical bits
Re: S3 electrical bits
Any pics Dave?
All my stuff if off the car and I have nothing to check it against now lol
95 FD RS in black
This is the oscillator.  Mounted in the engine bay, in front of the battery close to the headlamp.  According to rx7.com, this is the source of my incessant buzzer and replacing it is the best option.
Some say that you can simply remove it and run without. Will do some tests to see if this is true by draining oil / coolant and seeing if I still get warning lights with the oscillator out of the loop.
Unplugged the thing and buzzer stopped. I think this thing controls the buzzers and beeps associated with warning lights ie low water and headlamp on warning. That's my best guess as the wiring diagrams are inconclusive.
Anyways. does anyone have one what I could use? And I suppose I should clean the pins up and reconnect it just in case it's that simple??
if cleaning the pins doesn't help. I've probably got a few kicking about Dave, give me a shout if you need one
Well, the cleaning option has not worked.. give me a heads up if you find one in amongst your bits and bobs Ian.
will do DaveKiwiDave wrote:Well, the cleaning option has not worked.. give me a heads up if you find one in amongst your bits and bobs Ian.
