Hi all,
I have a 12A Aluminium flywheel for sale. It comes with clutch and pressure plate as per the photo. I will update you all with more info on the set up/cost in my next post.
Toby
12A Aluminium Flywheel
- DSCF0822.JPG (147.4 KiB) Viewed 2061 times
- DSCF0821.JPG (153.34 KiB) Viewed 2061 times
Re: 12A Aluminium Flywheel
Interested. Price (PM if you like)?
Here is the run down
I have just found the receipt of purchase to work out a good price. I bought the kit from the US for $548 that was delivered (not including import tax). The clutch was working fine when removed from my car but I am not sure how much life it has left in it. It has done only a couple thousand miles but hard miles. The flywheel is in excellent condition. From memory the clutch was rated to 305hp. Alternative pressure plates and clutch plates can be used with this flywheel to rate it higher.
I would like £200
Tool I will PM you soon.
Cheers,
Toby
I would like £200
Cheers,
Toby
Ok guys,
If anyone is interested ill drop the asking price £150. Its no use to me sitting around.
Cheers,
Toby
Cheers,
Toby
Dan Dillinger
Would this work ok with the clutch you sold me?
1982 - Mazda SA22c import
Hi Toby Im very interested, just wondered which size is this? 215 or 225 and do you have a matching counterweight at all? Is it a racing beat fly?
Thanks
Jon
Thanks
Jon
