Re: TWiR 1986 S3 TWR
Posted: Sun Jul 04, 2021 11:51 pm
It's been a frustrating few weeks trying to chase and rectify issues. My initial diagnosis of a faulty viscous fan was only partly correct.
Step one was installing an electric cooling fan
And a fan controller to monitor the actual coolant temps rather than trusting the OEM temp gauge. Thanks Jesse for the great deal
Early static testing had the OEM guage still reading unusually high while the fan controller proved that radiator temps were fine. So best try a new sender then, more on that a bit later.
Next stage was a short drive. Within ten minutes, OEM guage is 3/4 up the scale but a quick engine bay check reveals coolant temps are still good. I decided to head back anyway as the traffic was going nowhere fast.
Turned out to be a wise decision ...
Things had gotten a litle melty for some reason!
For reasons yet to be understood, this connector didn't appreciate being used as a 12v ignition source
It was a wire from the connector that I used that got hot inside the main connector block. That block was resting on a cable tie and it was the plastic cable tie that melted, caught fire and started to melt other stuff. Damage looks a lot worse in the pics.
Black blob in the center is the melted remains of a cable tie. That is what burned and caused the melted mess although I probably got off lightly.
So began the unwrapping of the loom section to establish damage. The heat damage made the wiring closest to the plug unusable, First thought was to unpin the plug and replace the wiring with a stripped down section that I already had.
Turns out, the pins on there were not compatable with the plug anyway so I had stripped the damaged loom for nothing. Plan B was to source an entire loom section. One call to Tim at RX Motors had that sorted.
So ... while I'm busy with refitting wiring and getting the fan to not melt anything, I have a curious dilemma to sort out with regard to the coolant temp sender. Having replaced one before on my previous motor, I know that it should be M8 diameter thread. This duly arrived from RockAuto and turned out to be too small.
Thanks to Pete (DKWW2000) for sending what should be the proper item, nah, thats also too small
The sender that I've removed from the rear plate / iron is M10 diameter and it has me stumped.
The one on the right removed from the car. Left from RockAuto and Pete.
You can see the difference here M10 (R) vs M8 (L)
edit ... a little more investigating
has turned up some helpful photos with what might be a potential solution. Quite expensive as a mazda part from Mazdatrix / Atkins but a quick cross reference on Rockauto gets me an OEM eqivalent for 1/4 of the price so it's worth the gamble.
