1985 S3 FB Breaking.
shaunwil
Re: 1985 S3 FB Breaking.
Post by shaunwil »
I don't seem to have access to reply to pm's ! I'm up the road in penwortham. I'm not sure the gearbox will fit a 12a turbo engine, Its more down to the clutch and flywheel configuration. I had it bolted up to a 13b egi engine with an egi clutch and flywheel.
I'd probably only really want £50 for it, Your more than welcome to come and have a look at it.
Shaun
PatrickS9
Post by PatrickS9 »
shaunwil wrote:I don't seem to have access to reply to pm's ! I'm up the road in penwortham. I'm not sure the gearbox will fit a 12a turbo engine, Its more down to the clutch and flywheel configuration. I had it bolted up to a 13b egi engine with an egi clutch and flywheel.
Shaun
OK, I've tried to read up on the egi config. The clutch I have is 225mm / 22 spline.
My number is 07515256633.
If you give me a text, I can come round this afternoon if you're free or Monday evening?
Cheers,
Patrick
shaunwil
Post by shaunwil »
Monday night is better (after 6pm), I'm out tonight bowling in Preston. I'll text you my postcode.
Best Regards
Shaun
PatrickS9
Post by PatrickS9 »
Gearbox bought!
Cheers!
Locked
Return to “Breakers”
