I don't seem to have access to reply to pm's ! I'm up the road in penwortham. I'm not sure the gearbox will fit a 12a turbo engine, Its more down to the clutch and flywheel configuration. I had it bolted up to a 13b egi engine with an egi clutch and flywheel.
I'd probably only really want £50 for it, Your more than welcome to come and have a look at it.
Shaun
1985 S3 FB Breaking.
Re: 1985 S3 FB Breaking.
shaunwil wrote:I don't seem to have access to reply to pm's ! I'm up the road in penwortham. I'm not sure the gearbox will fit a 12a turbo engine, Its more down to the clutch and flywheel configuration. I had it bolted up to a 13b egi engine with an egi clutch and flywheel.
Shaun
OK, I've tried to read up on the egi config. The clutch I have is 225mm / 22 spline.
My number is 07515256633.
If you give me a text, I can come round this afternoon if you're free or Monday evening?
Cheers,
Patrick
Monday night is better (after 6pm), I'm out tonight bowling in Preston. I'll text you my postcode.
Best Regards
Shaun
Best Regards
Shaun
