Electronic powered steering ?
Victorsanders
Has thanked: 59 times
Been thanked: 97 times
Re: Electronic powered steering ?
Post by Victorsanders »
Porters2 wrote: Tue Jul 29, 2025 12:36 pm
Victorsanders wrote: Tue Jul 29, 2025 12:15 pm
Porters2 wrote: Tue Jul 29, 2025 10:02 am :thumbup:
It’s not pretty, but it’s 20 years old NOS lol.
Yours if you need it matey.
Steve.
You sir are a legend! Yes please.. pop me a WhatsApp with how much you’re after please mate and il send it over
Don’t be daft, I will whack it in the post when I get a chance, I’m up to my neck in a wheel bearing on my daughters audi at the moment.
Well thank you Steve! Much appreciated!
Oh dear that doesn’t sound fun 😂
Has thanked: 505 times
Been thanked: 450 times
Where i need some advice is on the ignition live … I could easily connect up to IGN.. but the pump would immediately start drawing 50amps.. where can I find a 12v supply that is only live once the engine has been started ?
No really easy answer I can think of - maybe others can?
So, oil pressure, alternator voltage and engine revs are the obvious indicators that the engine is running and could be used as "sensors". Of these, the easiest solution I can think of would be to have a voltage detector on any available +ve battery circuit to trigger a circuit to operate a relay when the voltage is greater than ~13 volts, i.e. when the alternator is running. That's exactly what you want anyway, the 50A draw to occur only when the alternator is charging. You'd have to ensure the suddent 50A draw doesn't drop the voltage too much, else the trigger would oscillate on/off - maybe a Schmitt Trigger in the circuit would assist in preventing this. A bit of experimentation with the best trigger circuit and voltage setting might be needed.
Having done a bit of research, these "off the shelf" solutions would seem to have the functionality required:
A "Battery Protector" should do the job, (~£20), but is only rated at 10A, so an additional relay would be needed:
Link
Alternatively, this device, (~£30) would appear to do the job very neatly:
Other options:
This module, with the addition of a higher Amperage relay (or changout of the on-board relay);
Ebay link
Also, there are VSR's (Voltage Senstive Relays) that might do the job very simply. I've never used one but, technically, it looks as though it should do the job: Link
There are programmable VSR's (PVSR's) too, with some built-in voltage trigger points: Link
Plenty of cheaper PVSR variants on Amazon too: Link
WARNING: All the (P)VSR's are designed to operate by connecting to a secondary battery and a load (such as your pump), but I can see no reason (from the published data) why these devices shouldn't work with just a load and no battery, but "AI" says a secondary battery is essential for VSR's to work.....
Some ideas to mull over :D
Hmmm, having looked at the Victron solution a bit more closely, it's unclear what mode the device will take as IGN is turned on initially (Load ON or FFF). It may not be suitable for your application.
The "Battery Protection" device, with an extra relay for loads over 10A, looks to be the simplest solution to implement.
Victorsanders
Casey wrote: Wed Jul 30, 2025 12:07 am Hmmm, having looked at the Victron solution a bit more closely, it's unclear what mode the device will take as IGN is turned on initially (Load ON or FFF). It may not be suitable for your application.
I wasn’t expecting such a detailed response Malcolm thank you for that kind sir!
I shall look into the battery protection device also… worst case scenario I could always put it on a separate switch.. I won’t be using the headlight washer switch any longer.. this could be a tidy way.. I could even fit a beeper that comes on of the ignition is switched off and this remains on.. something to remind me to switch it off!
I shall test your method first and go from there !
Thank you again!
Return to “Electrics”
