s2 limited slip differential no preload?
Re: s2 limited slip differential no preload?
About 2mm. I was told if i should need new plates the later ones should fit, too.
Rotary Engines: Behold the power of two doritos on a stick!
Plates are same diameter.
Where’s the extra conical spring thickness made up? The casing?
Looks like. The space for the clutch packages is a bit shorter.
