See here: http://www.ebay.co.uk/itm/300637682894? ... 1497.l2649kenwhiteside wrote:Castrol would be my usual having run gtx magnatec in my subaru turbo for years. GTX is part synthetic though? Do you run 10w40?
http://www.opieoils.co.uk/p-69385-castr ... e-oil.aspx
Definitely part synthetic. You can get a full mineral oil from Halfords but my plugs don't foul and I get good cold and hot starting. If you're really keen. Go full synthetic, remove the OMP and premix with 2 stroke.
My Mazda RX-2 manual says Castrol GTX 10W40 for -18C to 40C and -10C to 40C spec is 20W40 or 20W50.
I run a twin dizzy engine too so I can use the same oil in both twin dizzy and FB (or other) engines. No difference between a 10W40 and a 20W50 as far as I'm concerned.
