Ha ha, even if new you could pretty much open the old Mazda door locks with a blunt lolly stick lol.
Lock barrel polishing?
- Has thanked: 112 times
- Been thanked: 133 times
Re: Lock barrel polishing?
- Victorsanders
- Has thanked: 59 times
- Been thanked: 97 times
Haha luckily mine are pretty secure and only open with the key.. iv been working away pretty much non stop and am being sent away again on Thursday .. so I’m not gonna have a chance to get this done this side of Christmas .. but when I do, il upload some photos
- Has thanked: 627 times
- Been thanked: 218 times
Sounds good. I had debated polishing mine. But mine are also possible to open with a table spoon if I wanted (yes. I have tried
). They could do with being rebuilt if possible
- gt_james
- Has thanked: 114 times
- Been thanked: 211 times
I have accidentally locked the keys in the car a couple of times, with no spare. Wasn't hard to open! One of my projects for next year is an alarm...
- Casey
- Has thanked: 505 times
- Been thanked: 450 times
Interesting. Do any of the UK spec cars have the door lock illumination option fitted? I've never noticed it!
According to the US websites, the external door lock light is illuminated by a slight raising of the door handle. That might explain a mysterious green wire that is connected to the car's CPU and I've traced to the lock area on the driver's door in the past and wondered what it was for. It does go to a circuit which operates the ignition barrel light. Maybe the wiring is installed, but with no handle switch and light on UK S3 cars?...unless I've simply not noticed it!
- Has thanked: 473 times
- Been thanked: 253 times
"It does go to a circuit which operates the ignition barrel light."
That's correct. When i raising of the door handle on my rx7, both lights are shining.
I think it's more easy to find the right position for your key in a dark night then.
- Casey
Wow, I never realised that! I saw it on the wiring diagram ages ago, when I was researching the "CPU" functions, but thought, like many other things in the diagrams, it was on US spec cars only.
I've just checked mine and I can see the switch cover is translucent, but the light doesn't work
Most likely the bulb has blown or, less likely, the switch doesn't operate. I can check the switch pretty easily by detaching the green wire to the CPU and checking for continuity to ground when the handle is lifted. Something to add to the list
- A7RXY
- Has thanked: 156 times
- Been thanked: 61 times
Good luck ....Casey wrote: ↑Thu Jan 11, 2024 5:55 pmWow, I never realised that! I saw it on the wiring diagram ages ago, when I was researching the "CPU" functions, but thought, like many other things in the diagrams, it was on US spec cars only.
I've just checked mine and I can see the switch cover is translucent, but the light doesn't work![]()
Most likely the bulb has blown or, less likely, the switch doesn't operate. I can check the switch pretty easily by detaching the green wire to the CPU and checking for continuity to ground when the handle is lifted. Something to add to the list![]()
