Thanks again guys.
I think the photos make it look tidier than it is Ian! But yes I've spent a fair amount of time trying to think about where everything will go and not rushing too much so it doesn't have a lashed-up feel to it.
I've put about 300 miles on her now, and she's running quite well. The fuel consumption is currently matching my stock set-up around town, which I'm quite pleased with seeing as I'm not longer using the primary/secondary system which will hurt the economy. I've not taken her on a long enough A roads and motorway drive yet where I've not been working on the map (lots of accelerating and driving in the wrong gears to reach all areas of the map) to know whether I've gained any extra urban economy.
The pickup from idle and throttle response has definitely improved, I think lots of this is down to the ignition mapping. Looking at the maps used in FCs and FDs the increase in advance is not linear like a dizzy provides and applying that same shape to my map has definitely improved the response below 3k rpm. Likewise on the timing, adding some more advance above 5k rpm seems to have it rushing to the redline harder. When I get on the dyno I'm going to mostly be tuning the ignition map and intended to get some back to back printouts with my electronic tunes ignition map vs what the dizzy provides.
The fuelling at the moment isn't perfect. On the whole its better than the carb at providing the right AFR across diverse loads, but there are moments where the map isn't quite right yet and it will spike lean or rich. Poorly tuned EFI tends to feel much more 'lumpy' and likely to kangaroo where as a poorly tuned carb often just feels a bit 'flat'. I've spent a bit of time working on my acceleration enrichments recently which is helping lots, but I really need more time with a wingman to work the laptop for me to finely tune them, so I might end up doing that on the dyno.
Starting is OK but not great at the moment, it always started but might take 3-5 second to catch. The starting algorithm takes into account the main fuel table so I'm waiting till thats set in stone before I get to worried about fine tuning the start up.
The one thing that's a bit frustrating right now is the idling. Most of the time it idles fine, just every now and them the revs drop to fast and it doesn't catch itself. When I get chance I'm going to triple check my throttle balancing so it's not trying to idle on one rotor, and I think I need to adjust the timing and fuelling so it starts to slow down the rev drop before it comes into the idle zone.
So yeh now the Megasquirt is installed there's always some small part of the mapping that be be adjusted and made just fractionally better, the key is working out when to say enough is enough!
AS I've said on a couple of other places where I post about Rexanne, for now this is her 'finished'. I just want to drive and enjoy her for a while now. There's always going ot be maintenance to do and when the weather warms I need a second shot at the paintwork on the drivers rear quarter but on the whole I'm not going to be starting any major projects for a while*
*not unless I find the right GT Junior.....
