Although my car passed the MOT, the tester did mention a slight drag on both the front brakes, so I thought I should check it out. I had, not long ago, cleaned and re-greased (Ceratec) the sliders, so, unsurprisingly, that wasn't the issue. Nor was it a hydraulic issue. The pads were also freely sliding on the end clips and the "Z" spring was in position correctly. However, the pistons were not retracting freely, so I decided to remove the driver side caliper first to take a look. Before disconnecting the hydraulic line, I used the brake system to push out the piston into a block of wood, having discovered from experience, this is the best way to get the piston out.
The caliper needed some TLC!
- Driver side brake piston caliper , before cleaning.jpg (64.82 KiB) Viewed 12638 times
The piston seal and rubber boot were in excellent condition, but I have a new set, so will use those on re-assembly.
- Driver side brake piston, after cleaning 2.jpg (55.01 KiB) Viewed 12638 times
The inner bore was fine, and so was the piston, but I couldn't slide the piston back in as rust had accumulated around the bore outside the piston seal. Here I have removed the piston seal and started to remove the rust. Once finished, without the seal replaced, the piston slid freely in and out.
- Driver side brake piston caliper bore.jpg (76.29 KiB) Viewed 12638 times
I removed all the rust I could, degreased the caliper and gave it two coats of Hammerite smooth silver. Nearly ready to re-assemble, just waiting for the Hammerite to cure - it still seems a little soft and tacky after 24 hours
- Driver side brake caliper kit.jpg (126.95 KiB) Viewed 12638 times
