'80 13BT Series 1
Been thanked: 111 times
Re: '80 13BT Series 1
Post by Chud »
rotarypower wrote: Mon Apr 20, 2020 8:08 pm Great work on the underside of that bus.
Could I ask what you used as the finish on it, is it Raptor Liner or something similar?
That the effect that I'm looking for.
Cheers, yeah it’s textured raptor - the 7 will get the same stuff.
Re: '80 13BBP Series 1
Post by Chud »
gt_james wrote: Mon Apr 20, 2020 3:15 pm Be good to sort that pesky rust out, your black S1 is such a cool car! any plans for that other S1?
Cheers James, I’m unsure about the other S1 as I haven’t had a chance to give it a proper prod. If it’s solid enough it could make a cool track car - it’s got a webasto sunroof which is annoying and it’s very rough and ready. I need a donor really as I’m toying with converting to right hand drive and it’s got a good uncut dash so in that respect maybe would be good for that. I haven’t seen my series 2 in ages as it’s in storage too and needs retrieving - last time I saw it when I moved house there was localised bubbling here and there. Perhaps a better candidate for donor metal, but then I’ve had that one the longest - probably 15 years now so there’s a certain attachment.
I’m blathering a bit, the short answer to your question is, I don’t know.
Has thanked: 441 times
Been thanked: 181 times
That rust should be no issue compared to the Porsche aye bro! Oh crap. I might get some of that reflective heat tape for my bonnet now :shock: :lol:
Post by Chud »
:lol: I would mate.
Post by Chud »
The whirry bit is finished. E shaft balanced, rotors weight matched - standard stuff really. Should sing pretty good with the bridge and quads.
Decided to run a 12A box for a minute as a) I can’t be arsed with modifying the prop/shifter housing/mount and b) I have everything here I need to build it with a 12A. What I don’t have is a GSL-SE sump so before I order one from the USA if anyone has or knows of one please shout. Thankings.
Has thanked: 300 times
Been thanked: 146 times
Post by Chud »
Cheers Dave
Post by Chud »
The 912 is on the road and survived the dyno, but we’re not here for that - she’s finally in. It’s her turn.
Post by Chud »
So with cuts of the back end taken from the donor to repair the rear hatch rot the first job is to get all the suspension off and stripped. I’ve got the coilovers so the struts can go in the spares pile, I’m keen to use a set of radial mount wilwood 4 pots I’ve got hanging about so will experiment with them to see if they’ll fit under the 14’s. I’m tempted with 4 link, but then again her interior is so good and original maybe this isn’t the one to do that on.
Looking forward to this, and after doing the 912 it’ll be refreshing to work on something I’ve already got a ‘relationship’ with and also doesn’t cost a gazillion pounds to buy parts for.
I still want some US spec rear lights.....
Has thanked: 127 times
Been thanked: 39 times
Good luck .... can't wait to the next instalment and some photos
Dids
