Sticky window
CarrieBee
Has thanked: 5 times
Sticky window
Post by CarrieBee »
My passenger window sometimes sticks when it's fully down. I am not sure if it's an electric issue or a 'sticky window' issue. Anyone had this before? What fixed it?
Has thanked: 505 times
Been thanked: 450 times
Re: Sticky window
It might be the switch. it's fairly common and I've suffered the issue on two FBs. It's fairly easy to remove the switch, dismantle it carefully, clean out all the muck you'll find in there and re-assemble.
Have a look at this topic: viewtopic.php?f=22&t=1783
Having said that, if the switch were at fault, I'd expect the issue to be present on both winding the window up AND down, so more likely the glass is sticking in the runners. I'll let others comment on the best way to fix that.
CarrieBee
Re: Sticky window
Post by CarrieBee »
Casey wrote: Tue Aug 04, 2020 11:11 pm It might be the switch. it's fairly common and I've suffered the issue on two FBs. It's fairly easy to remove the switch, dismantle it carefully, clean out all the muck you'll find in there and re-assemble.
Thank you. I will take a look at this! Appreciate your advice.
DeanRX7
Has thanked: 39 times
Been thanked: 63 times
Re: Sticky window
Post by DeanRX7 »
Cleaning the switches worked for me though the drivers side motor is more tired than the passenger side for sure.
Has thanked: 473 times
Re: Sticky window
Change the switch left and right cause you normally more often open the driverside window.
Return to “Electrics”
