KIMI 3 - 1984 Series 3
danny
Has thanked: 5 times
Been thanked: 130 times
Re: KIMI 3 - 1984 Series 3
Post by danny »
I will see into this matter at a later day. I will keep you guys posted.
Good luck Malcolm getting that all back together, almost lucky not being able to nip down to the pub.
g-l
Has thanked: 512 times
Been thanked: 455 times
Another small but satisfying job on a nice sunny (lockdown) day :D
I've never liked the look of the amateurish rear fog lamp so decided to do something about it today:
Before:
2020-04-10 11.32.52_1024.jpg (169.58 KiB) Viewed 8410 times
After:
2020-04-10 11.56.43_1024.jpg (154.2 KiB) Viewed 8410 times
I used an red LED lamp in the driver side rear reversing slot for this, so decided to switch the reversing lamp on the other side for a white LED lamp at the same time:
2020-04-10 11.23.13_1024.jpg (132.85 KiB) Viewed 8410 times
A simple task, details to follow for anyone wanting to do this.
Here are the lamps I used, plenty of choice on Ebay:
2020-04-10 11.21.04_1024.jpg (196.85 KiB) Viewed 8410 times
The installation of the OEM fog light was pretty shoddy:
Cheap, non-auto connector:
2020-04-10 11.30.52_1024.jpg (82.86 KiB) Viewed 8410 times
The installer didn't even bother to route it via the grommet!!
2020-04-10 11.31.56_1024.jpg (150.23 KiB) Viewed 8410 times
It was a simple job to reroute the red fog lamp wire into the multiway rear light cluster connector, removing the red/white wire and crimp, inserting new female blade crimp. I even managed to get some new crimps that look almost identical to OEM (not that anyone is going to see it!) ;)
2020-04-10 11.20.17_1024.jpg (162.93 KiB) Viewed 8410 times
2020-04-10 11.50.11_1024.jpg (68.77 KiB) Viewed 8410 times
It looks so much neater aye! One of the first things I done to the 7 Haha th:
rotarypower
Has thanked: 94 times
Been thanked: 71 times
Post by rotarypower »
So is it just the bulb?
Or did you actually remove / cut out part of the rear cluster to make it fit?
Maybe I'm being stupid but it looks different in the photos.
Very simple, just the bulb change from white to red, and rerouting the fog lamp wire.
Thats what i have done whit the rear lights. No fog lights needed anymore :lol:
spirit r wrote: Sun Apr 12, 2020 7:09 am Thats what i have done whit the rear lights. No fog lights needed anymore :lol:
I did the same Thomas, looks better in my opinion :thumbup:
Another very minor task. The bonnet stay clip was broken when I bought the car. I found something that I thought should work on eBay - cost me £2.75 for TEN, so if anyone wants one, just let me know!
Before:
After:
I had to use a Dremel grinding wheel to shave off about 1mm of plastic from two sides, but it's a snug fit into the chassis and a snug clamp onto the bonnet stay.
The simple things :lol:
