Good advice. Haven't those reds been unobtanium since forever?
- Has thanked: 300 times
- Been thanked: 146 times
Scabs
What do you mean by they will need to be rebuit? I believe they are NOS
- gt_james
- Has thanked: 76 times
- Been thanked: 145 times
Why didn't you get a matched set of ACBRON rears? The arches look like they're coming on great
Scabs
From what I believe ACBRON don't do a rear set if dampners for the RX4. I've read konis are the vest if you can find them, luckily the guy I spoke to had a contact who still has some.
They are getting there! It's been a rather slow evolution and kind of wished I hadn't started fiberglassing them but they will look awesome when done that's for sure. Spent 11 hours today doing the opposite arch and was going to primer them up but It wasn't perfect and knew in the back of my head id kick myself if It turned out crap.
Unfortunately there won't be any update for a couple weeks as I'm away with work, I will update as soon as I get some more time on the car. Think I need a couple more days to
Grind off rear inner arch lip and weld it
Prep rear wells for fiberglassing with 180
Primer all the arches
Epoxy the underside
Then I can start getting the steering components and toework in for the mock setup. Still needing wheels though!!
Missed my delivery of KMAC sway bars today so will get them next week when I'm not here, also going to pickup the gearbox sometime when I'm back from being checked over and serviced.
- Been thanked: 10 times
There’s a plastic piece in the top that disintegrates over time and blocks the valve. You’ll need them rebuilt.
Scabs
Cheers for the info, I'll look into that - I'll more than likely just whack them on the car to be honest mateas I don't have any movement with my budget for the underside as I've gone well over! Should be ok I would have thought?
Time will tell and I'm sure at one point or another you will say "I told you so!" Haha
Jake
You’ll know cos they’ll be rock solid. Ask me how I know.
Scabs
Hi guys,
Haven't been around for some time and won't be for the next month die to work commitments.
Haven't been able to put any hours into her last month, but received both sway bars.
Looking forward to getting stuck back into it when I'm home! Thought I'd let you guys know that I haven't given up
Jake
Jake
- A7RXY
- Has thanked: 127 times
- Been thanked: 39 times
Good luck .... life gets in the way when you want to enjoy yourself...
- MelloYello
- Has thanked: 18 times
- Been thanked: 47 times
