Blast it!
Got any useful hints or tips on restoring our cars or the parts for it? Please share them here. General stuff only.... please put item specific info in the categories above
Blast it!
Post by ian65 » Fri Nov 17, 2017 5:35 pm
So i bought this from the restoration show a couple of weeks ago..... wanted one for years and finally got around to getting one.
I'm currently using crush glass blast media which is great on rusty parts but a bit severe for alloy..... it will probably calm down a bit once it's done a few cycles through the gun and broken down a bit but I want something a with a lighter touch to do my inlet manifolds....
Anyone else got a blast cabinet and what blast media do you use and for what? Any handy hints?
1986 Series 3 13B Turbo II
Re: Blast it!
Post by MelloYello » Fri Nov 17, 2017 5:51 pm
OOOoooohhhh fancy. Seems like one of those things that would be very satisfying to use.
I have had no experience but I have read that ground walnut shell made a good media to use.
Re: Blast it!
Post by Hobbawobba » Fri Nov 17, 2017 5:57 pm
I've always wanted one of these. I checked them out at the NEC Classic show last week. We have a good one at work but unsure if I'll be allowed to use it for my own stuff hahaha. Got any pics of before/after blasting?
Re: Blast it!
Post by Casey » Fri Nov 17, 2017 6:12 pm
Ooooooooooooooh, nice - I can't help with your query Ian, but I keep looking at getting one of those. Be very interested to see how you get on with blasting an alloy piece.
kenwhiteside
Re: Blast it!
Post by kenwhiteside » Fri Nov 17, 2017 8:37 pm
Bead blasted the alloy inlet manifolds on the elford then clear coated with high temp clear. Still looks good 2 years later.
Re: Blast it!
Post by ian65 » Fri Nov 17, 2017 9:14 pm
kenwhiteside wrote:Bead blasted the alloy inlet manifolds on the elford then clear coated with high temp clear. Still looks good 2 years later.
did you use glass bead or plastic?
kenwhiteside
Re: Blast it!
Post by kenwhiteside » Tue Nov 21, 2017 7:43 am
Glass beads I think. Gave a nice finish.
Re: Blast it!
Post by DB RX63 » Tue Nov 21, 2017 8:31 pm
I've heard that some companies use crushed walnut shells where they don't want to damage items, also some form of soda is sometimes used which is softer.
I used these guy's for my car, but surprised to just see that they have ceased trading.
http://www.blast-cleaning.co.uk/index.p ... rticleid=8
Re: Blast it!
Post by Casey » Wed Jan 24, 2018 7:39 pm
Couldn't resist a "VAT Free" voucher offer at Machine Mart and just lugged home a Clarke version of that cabinet. Might be a while before I can set it up fully, but I already have a bench full of rusty parts that need attention and doing it with wire wheels, etc, was getting to be a chore!
Re: Blast it!
Post by gt_james » Fri Jan 26, 2018 1:47 pm
walnut shells are used for rumble polishing, I'd have thought a bit soft for blasting.
