Idling problems with a JDM 12AT engine
Traxnada
Post by Traxnada »
Hello guys!
So, I recently replaced the trailing ignition control unit on my JDM '85 12a Turbo (EFI). Now the car works like it used to and I'm VERY happy with the results!
I still have a little problem with idling though. I would have thought changing the ICU would fix the problem, but nope...
Description: When cold, the idling makes me think a bit of a cammed V8 engine. It has some kind of a weird rhythm to it that has nothing to do with a rotary. Once the engine gets a bit warm, idling stabilizes itself but way too high, around 1300rpm. If I give it a bit of throttle (up to 3500-4000rpm) then let the RPM fall down to idling, it will stabilizes around 700rpm (a bit too low), but just merely touching the throttle, sends it back to 1300/1400rpm right away.
If I shut down the car for a couple of minutes, then turn it back on, the idling will be CammedV8-ish for 30s, then stabilize again at 1300-1400rpm.
Other than that, everything is great with the car. No problem at all, great throttle response and tons of fun. It's just this idling problem that is a bit annoying since my car is daily driven.
If anyone has an idea as to what might be wrong, I'm all ears :)
Thanks,
Flavien
Has thanked: 628 times
Been thanked: 218 times
Re: Idling problems with a JDM 12AT engine
I don't have a clue what the problem would be. But maybe uploading a video on Youtube might help a bit? :)
Traxnada
Post by Traxnada »
Hobbawobba wrote:I don't have a clue what the problem would be. But maybe uploading a video on Youtube might help a bit? :)
OK I'll do that tomorrow then :)
11pm here already so...
Sticking throttle cable or throttle body?
KiwiDave wrote:Sticking throttle cable or throttle body?
My first thought to Dave.
rdg th:
Traxnada
Post by Traxnada »
So I just came back from the car... Of course, because I was trying to shoot a video it hasn't caused as much problem as usual :lol:
Nonetheless, you can hear what I mean by weird CammedV8-ish idling at 4min40 and 6min05 in the video.
I will look for a slightly stucked throttle cable, but I doubt it is the problem... Could be nonetheless so I'll WD40 the shit out of the cable, we'll see :)
Oh that does seem quite strange (to me at least). Wouldn't a stuck cable would keep it at the same RPM rather than fluctuating? Love the car by the way! :o
Traxnada
Post by Traxnada »
Hobbawobba wrote:Oh that does seem quite strange (to me at least). Wouldn't a stuck cable would keep it at the same RPM rather than fluctuating? Love the car by the way! :o
Yeah, I doubt that's the problem either... To make it jump back from 700 to 1300rpm, I also merely have to touch the pedal, not even really pressing it. Not pressing it enough to make to gain 600rpm anyway...
And thanks :)
Has thanked: 5 times
Been thanked: 23 times
Post by DB RX63 »
Check all of the ignition components, plug leads, coils, distributor cap and rotor etc. Often these things can be electrical when they seem mechanical.
