Not only can you not see this nut, I had to take this photo to see where it was, you can only get one finger on it let alone get a socket on it, as you can see from the next photo I had to grind some of the exhaust manifold, bottom left in this photo, when this photo was taken the heatshield has been removed as the inlet is out of the way.
But this was sized solid because of the leak. Well 3 weeks later Today I got the bugger out .......I've had to buy a 1/4 drive socket set, wobble bars, and lots of grinding bits for the Dremel.
Now to put it all back .......
Any tips about fitting the new gasket and O rings ie do I use Vaseline to hold the ring in place, I would also like to replace the bolts for new, are these special bolts ? or just 12mm.
PS I will not be polishing any of the parts before they go back just cleaned.
