LSD Oil
Re: LSD Oil
I use something like this in my clutch type LSD.
http://www.opieoils.co.uk/p-736-castrol ... w-140.aspx
See page 8 of this:
http://www.foxed.ca/rx7manual/manuals/t ... 20DATA.pdf
See page 8 of this:
Re: LSD Oil
I use Amsoil Synthetic Gear Lube SAE 75w-90 with one 114 ml bottle of AC Delco (general motors) LSD additive. Part # 1 # 992694.
I have used this with both the stock series 2 LSD and the Mazda factory race LSD. Not sure of UK availability.
When in doubt....hit the gas.
Re: LSD Oil
do you reckon this will work in my lsd? Looking at the spec Tool linked to, this seems to be the stuff.... I don't really want to shell out £30 for synthetic until I know it all works as it should and there are no problems.... this seems a bit more reasonable....
http://www.ebay.co.uk/itm/Motul-90-PA-L ... 2a2f164b82
Re: LSD Oil
I go for the higher 75-140 hyoid stuff.
This is exactly what I use:
http://www.ebay.co.uk/itm/Castrol-Syntr ... 27d9a6418e
If there's something wrong with your diff, you can always drain it out and reuse it. Just put it through a coffee filter to remove the chunks.
I doesn't say much about your LSD supplier though
Re: LSD Oil
I'm sure the diff with be spot on... I'm more worried about oil leaks from the casing where I've put it all together etcTOOL wrote:I go for the higher 75-140 hyoid stuff.
Re: LSD Oil
Just ordered the same, cheersTOOL wrote:I go for the higher 75-140 hyoid stuff.
Re: LSD Oil
ausrotary.com/viewtopic.php?f=4&t=206546&p=2524787&hilit=LSD+oil+140#p2524787
Ok lloyd12a, find me some of that. He's massing loads of mfr parts for a build and knows his stuff, but I disagree with him here.
- Has thanked: 5 times
- Been thanked: 23 times
Re: LSD Oil
All I know about diff oil !
Clutch type LSD's need a certain type of oil.
Torsen type LSD's can use std diff oil.
I'm using Redline synthetic stuff in my gearbox and diff, Red Line MT-90 it is, bit pricey mind.
DB
DB
