FC Crank sensor + coils + Other s5 13bt parts
Steve-A
Post by Steve-A »
Hi guys, I'm sorry that my first post on here in a long time is just selling stuff, but hopefully it's all for the best in the long run*. Unfortunately due to water seal/centre plate failure my 13b has come out of my mx5 and it wont be going back in. This means I'm hang a clear out of rotor parts, and I thought of the few of the parts might be of use to FB owners who might want to convert to fuel injection or electronic ignition.
All parts are located in Bromsgrove, Worcestershire. All prices open to offers.
First up Ive got a pair of FC turbo crank angle sensors. £50 each posted :)
Next up is 2 sets of FC coils, you can use the leading coil packs to convert to direct fire on a 12a while keeping the dizzy, or again if you wanted to go fuel injected you'll need these! They are missing their original FC connectors, from where they were directly soldered into my loom but if you were using them in an FB you'd be doing something similar anyway! £50 for a leading + trailing posted.
Less likely to be useful to you guys but….
I've also got a reasonable 13bt s5 rotor housing. It's in reasonable condition, a bit dirty, there's one very small section of chrome damage pictured, it's 1.5mm wide so less than he Mazda spec of 2mm :) £80?
13bt s5 front and rear plates. They look to be in good condition to me, very little stepped side seal wear etc. They are a bit dirty, the rear plate has the coolant outlet to the throttle body blocked off. £75 the pair?
I've also got an auto counter weight, a pair of rotors, stationary gears with good bearings, oil pump and all sorts of misc small bits from the same engine available for beer tokens. Let me know if there's anything you need.
* I think long term I'd rather have another FB rather than the modded mx5! 8-)
Re: FC Crank sensor + coils + Other s5 13bt parts
Alternator?
Steve-A
Post by Steve-A »
Yup got one of those :) Again from an FC s5 so its an 80A one.
Not sure on value, £35 posted sound ok? I did look on eBay but the prices are clearly stupid, Jimmys wants £75 for one….
Would be a great price, but I dunno if it's suitable for my S3. According to Ian's alternator fitting guide http://www.rx7fb.com/viewtopic.php?f=22&t=127 those ones "aren't worth the hassle of modifying to fit" :cry:
Has thanked: 628 times
Been thanked: 218 times
Just some minor rewiring aye, Nik! Bro I've been meaning to text you the last few days haha. Do you have the little brown plug that goes into the alternator? Can't remember if I saw one in your stash at all :lol: Unless Nik wants it for if he decides to grab the s5 unit :D
Steve-A
Post by Steve-A »
Jesse, yes I do have the correct brown plug for the alternator :) I'll let you and Nik fight it out for who wants the alternator :P
I already have an alternator! :D I was just thinking that the plug connector would come in handy for when I eventually install in haha
Steve-A
Post by Steve-A »
Oh yeah, sorry mate, wasn't thinking. You can have that plug next time I see you :)
Return to “Parts For Sale”
