Ok, So i'm replacing my swaybar with a stiffer one so I now have no need for the pair of standard size (23mm) Energy Suspension bushes I was planning to use. These are the Black graphite impregnated ones and are to fit the stock front swaybar in the middle - these are not the end links.
Looking for £12 including postage in UK.
Any takers?
Pair of 23mm Front sway bar bushings (Polyeurethane)
Re: Pair of 23mm Front sway bar bushings (Polyeurethane)
Hi do you still have these and will they fit a 1983 s2 as I am looking for a full poly bush kit for my rx thanks
Raymond
Raymond
biznatch
Hi Raymond,
They are still available. I only have the two sway bar bushings that hold the middle of the bar, not the end links if that makes sense.
PM me if you want them.
Biznatch
Biznatch
