Posts: 6402 Joined: Wed Mar 30, 2011 12:11 am
Has thanked: 315 times
Been thanked: 376 times
Post
by ian65 » Sat Oct 29, 2011 8:50 pm
anyone running one of these??
"Moog idler arms have an internal wear take-up spring that absorbs shock and vibration for smoother, safer movement and maximum durability. A patented pressed-in cover plate eliminates excessive play and allows for tighter tolerances. These idler arms use powdered-metal gusher bearings with grease grooves to improve performance and service life. This approach allows grease to flow through the bearing to the stud and provides a smooth, durable surface that extends service life. Moog idler arms also use a double-tapered bearing design that decreases deflection and helps preserve proper toe setting, and they have a larger bearing surface area that distributes the load more evenly."
supposed to be the bees knees but are they worth the expense? (£69.00) shipped
Posts: 1565 Joined: Thu Mar 31, 2011 10:54 am
Has thanked: 40 times
Been thanked: 37 times
Post
by myatt1972 » Sat Oct 29, 2011 9:50 pm
I thought it would be more than that, would be good to get feedback from someone who has one.
If they are good I'd certainly be interested in one.
Post
by ian65 » Sat Oct 29, 2011 10:00 pm
I know the racing guys use them but being bearing based, they should be 'fit and forget' and take some of the looseness out of the steering.... idler arm bushes, even genuine Mazda, don't last 5 minutes.
If we order 2 then the price is as follows:
Price each £34.58
X2 £69.16
Shipping £41.30
Pre paid vat £22.09
Total £132.55...... so £66.00 each delivered
Post
by myatt1972 » Sat Oct 29, 2011 10:04 pm
Are they available for rhd cars or will they swing round for either ?
Posts: 1342 Joined: Fri Apr 01, 2011 6:55 am
Has thanked: 156 times
Been thanked: 61 times
Post
by A7RXY » Sun Oct 30, 2011 10:06 am
Ian if you want to share the cost further then I would also be interested, anything that can stiffen up the steering can not be a bad thing.
Post
by ian65 » Sun Oct 30, 2011 10:27 pm
it's just something I'm thinking about at the moment Dibs...... but if I do order one, I'll give you a shout
Post
by A7RXY » Mon Oct 31, 2011 6:03 am
ian65 wrote: it's just something I'm thinking about at the moment Dibs...... but if I do order one, I'll give you a shout
Thanks
mc turbo
Post
by mc turbo » Sun Dec 08, 2013 2:18 pm
hi ian do these fit rhd fb`s? & where can get one from? cheers
Posts: 2668 Joined: Fri Apr 01, 2011 11:41 am
Been thanked: 4 times
Post
by codge » Sun Dec 08, 2013 3:54 pm
No, we checked with the supplier and they're not reversible to fit RHD. Pity that.
Posts: 933 Joined: Fri Apr 01, 2011 7:35 am
Has thanked: 3 times
Been thanked: 111 times
Post
by Chud » Wed Dec 11, 2013 7:40 pm
I've got one on the lhd SA - feels as good as you'd ever hope it to. Better than the standard replacement I've got on NEV anyway.
