1985 GSL-SE LeMans car based Racecar
				MishlerDennis
Re: 1985 GSL-SE LeMans car based Racecar
I truly wish i could but that is the FB that I am building this racecar in remembrance for..
				MishlerDennis
Industrial Epoxy Primer was laid today on everything but the interior and undercarriage, been shooting primer sense 9AM it is now 8PM.. Fun Fun. Pics being posted up in the morning.
				MishlerDennis
A little late on the pictures but here they are. Finishing the paint after the widebody is finished. I will post pictures of the widebody project as it goes, so much foam and bondo so little time.
- IMG_20130821_184253.jpg (318.32 KiB) Viewed 4803 times
- IMG_20130821_184336.jpg (391.56 KiB) Viewed 4803 times
				MishlerDennis
I will be reposting pictures of the primed stuff as soon as I can off my MacBook Pro instead of my phone.. Phone takes horrible pictures.
Awesome project pal.
You can buy the 26b crank and bits in New Zealand
				MishlerDennis
If it cost less than $7000.00 then please post a link to the company. I found an e-shaft but its from mazdaspeed and cost seven thousand dollars.
Jeff Bruce is the man you need to speak to as I believe he supplies most of the kits.
http://www.precisionengltd.co.nz/rotary.html
Green brothers in Tauranga/Mt. Maunganui (NZ) has 4 rotor eshafts. Ask for Richard.
http://greenbrothers.co.nz/Products.html
He had 3 20Bs on the shelf getting built last time I was there.
Also Al Marsh in CHCH, NZ was building a 4 rotor when I was there about 4 months ago. You could ask him where he got his eshaft from. He's happy to discuss tehcnical stuff unlike some builders.
http://yellow.co.nz/y/al-marsh-automotive-christchurch
almarshrotorsport@gmail.com
